Problem using Recuva
Hi Folks
I'm trying to use Recuva to recover some documents on a memory stick. When the scan is in progress it says that it has found files but then it ends by saying incorrect parameter and does not any of the files. Any ideas on what I'm doing wrong?
Thanks
Moh
I too have had this problem: I don't know why it's caused, but I know that Recuva seemed to right itself after a few goes and a reboot or two, so that's what I suggest.
