Problem after I ran CCleaner
I just ran CCleaner and didn't look as close as I should have at the files it was going to delete before I selected to remove all. Now web pages look strange, I don't know much about the structure of a web pages but about all that I'm getting is very plain pages. The only part of it that I've ran so far is Cleaner/Applications/Analyze/Run Cleaner. Any suggestions? Will System Restore fix this? Many thanks
Rerun CCleaner with your browser(s) open. Next time, just close them before you run CCleaner.
MrG really needs to add a prompt and force browsers to be closed.
Thanks Tarun, I actually found alot of info on the problem in the bugs forum. Guess I should have looked alittle more before I posted. In some of the stuff I was reading it said they were working on a patch for this proplem with Firefox, do you know if thats out yet?
