Pro doesn't work complete
Although I hace the Pro-version the items Speed and Security don't work. Privacy and Space do well.
How do you mean that they 'don't work'?
If it's simply that they always show zero then that's normal.
Speed looks for unneeded entries in your Startup schedule - It should almost never find anything, (apart from the very first time that you run Health Check).
Security looks for updates to certain apps that you have installed - It will only show a number if something on it's list of installed apps is found to have an update available.
From the start speed and security didn't show anything. But I understand that's normal?
Thank you for your answer.
They do a check everytime you run Health Check - but will only show something if they find something that needs attention.
You can do the checks yourself if you want to see more about they are looking at on your machine.
Go to 'Tools>Software Updates' - that's the same as 'Privacy' - it will tell you that your apps are up to date, if you click on 'Up-to-date Programs' it will tell you what programmes it is checking on your machine.
Go to 'Tools>Startup' - that's the same as 'Speed' - it will show you 4 tabs of things that are set to start automatically (Yes or No) when you turn on the computer.
If you are not sure what those are then leave them alone and let Health Check decide which are not needed.
And again thank you. I have done what you told me and it appears to be ok.
Peter
