The two immediate safety tips at startup were interesting and applied one of the recommendations immediately. Boost also had a new startup advise.
One feature (or bug?) discovered and repeated that worked fine in 5.0.0
When running Boost, all items are deselected where the previous version 5.0.0 remembered to keep deselect active. Now I must use Select All and then again click over and over again all items not to be shut down, ie. Glasswire VPN & Firewall
Also the prompt for starting long tem Boost screen appears to be a nag screen — please turn it off or allow user to shut it down permanently
