I thought about posting this in the ongoing thread about partitioning a hard drive but thought that perhaps this may be better in its own thread.
I've just purchased a new computer, this one has a 320GB HDD, so it makes sense to partition the disk. As it's Vista I'm using Microsoft's own Disk Management Utility (DMU).
I've read through googling that a disk can have 4 primary partitions but then there are extended and logical partitions too, which has somewhat confused me...
This is what the disk was labelled as and divided into when I bought it:
C: HP partition (286GB)
D: FACTORY_IMAGE (12GB)
(Total HD being 298GB which is also the same as 320GB depending on how gigabytes are measured)
So IO don't think there is any other, hidden, partitions such as a Host Protected Area
I decided initially to shrink the C: partition to 60GB, more than sufficient but the DMU won't allow me to shrink that partition below 51GB anyway so I rounded it up to 60GB. I then created a new Simple Volume as the DMU likes to call the whole partitioning process and labelled this Data and Media. So now I had the following:
C: Vista (I renamed the partition) (60GB)
J: Data and Media (226GB)
Each partition shows in Disk Management as a Primary Partition, though of course the C: partition is also the Active Partition.
Upon further though I decided I wanted all my media (music and video) files to go into their own partition and having read around the internet I learned it was possible to have 4 partitions. So I decided to shrink partition J: and create another, fourth, partition for Media. However, this time the partition I created does not show as a Primary Partition but rather a Logical Drive. This is highlighted in Disk Management as the partition being colour coded blue (indicating Logical Drive) as well the graphical representation of the partition being surrounded by a green box (indicating Extended Partition). This is further shown if I decide to delete this Logical Drive, the space does not become Unallocated, as when a Primary Partition is deleted but rather Free Space. Further their is then a secondary choice to delete this Free Space, which shows in the right click menu as "Delete Partition" with a warning message then displaying is I choose this saying "This is an extended partition" and then warning about the partition becoming inaccessible etc. Deleting this then reverts the space to unallocated.
I apologise if this is long winded, it is at this point I am failing to understand:
1. why the 4th partition I created isn't a Primary Partition
2. am I right in thinking that the Media partition I created is a logical drive on an extended partition? If so, what is the extended partition an extension of?! Is it an extension of the J: partition above? If so, that's only 3 primary partitions I have been allowed before an extended partition and then logical drive appeared. I have tried and have found the extended partition can be divided into more than just one logical drive as I further split the Media (logical drive) partition to create a Media partition and a small Backup partition for computer maintenance (eg to store program set up files).
The more I read about all this around the internet the more confused I become... so could someone answer a few of queries for me (hopefully I haven't confused everyone as much as I've confused myself!)?
1. To have logical drives am I correct in thinking that the disk can only be divided into 3 Primary Partitions with the 4th partition being the Extended Partition, which can then be split into a number of Logical Drives?
2. Can I easily store data on Logical Drives without causing any problems for myself?
3. Ideally I would like the following setup:
C: Vista (60GB) (shows as Primary Partition)
D: FACTORY_IMAGE (12GB) (shows as Primary Partition)
J: Data (80GB) (shows as Primary Partition)
K: Media (120GB) (shows as Logical Drive)
L: Backup (26GB) (shows as Logical Drive)
(I assume K: and L: are part of the same Extended Partition)
Will I be able to fill all these partitions up with files without worrying about any access problems? For example, I'd hate to burn a number of my CDs to K: and then find I can't access the files somewhere down the line, or store all my project files on J: and then see them disappear.
Sorry for the length of this post, I'm not used to having more than 2 partitions to deal with on Vista so I need to be sure that what I have outlined above (at 3.) is perfectly fine and won't cause any computer problems or loss of data.
Thanks in advance for any answers or thoughts.
