I was going through Spybot S&D's Startup utility when i saw this
command line: crypt32.dll
crypt32chain is not safe according to processlibrary's process database
crypt32.dll is safe according to processlibrary's process database
You could upload the file/files to Virus Total for a scan with 30 or so AV engines.
If they come up suspect then maybe follow the guide "Please Read This First" in the Spyware Hell part of this forum.
Name: crypt32chaincommand line: crypt32.dll
This is normally legit, what probably got results as being a trojan is crypt32chain.dll, which is not the same as what you described. Unless you've been noticing other malware related issues, your probably fine. Either way though, it couldn't hurt to follow Humpty's excellent advice.
