Power Outage While Defragging
I was in the midst of a full defrag using defraggler and my power accidentally tripped resulting in cutoff of power to my PC.
My question is will this have any side effects on the defragmentation process should i run it again?
You shouldn't have any problems with that:
Why Defraggler is safe to use
Windows has an internal API (Application Programming Interface) that third-party applications such as Defraggler can use to move and delete files. This API works the same way Windows does when it moves or deletes files, and is very safe. Even if the PC crashes or you experience a power failure during defragmentation, Windows can usually complete the file operations or cancel them without file corruption.
Defraggler uses the Windows API, and is a safe and effective choice for your defragging needs.
Defraggler guide:
alright thanks for clarifying. just did a chkdsk to play safe!
