Tag & Rename 3.8 points to Tag & Rename 3.7 paths
[Tag&Rename 3.8]
ID=2398
LangSecRef=3024
Detect=HKCU\Software\Softpointer\Tag&Rename3.7\Config
Default=True
RegKey1=HKCU\Software\Softpointer\Tag&Rename3.7\Config|CurrentFolder
RegKey2=HKCU\Software\Softpointer\Tag&Rename3.7\Config|HistoryList
[TeamViewer]
ID=2395
LangSecRef=3024
Detect=HKCU\Software\TeamViewer
Default=True
RegKey1=HKCU\Software\TeamViewer\Version9|MRU
FileKey1=%ProgramFiles%\TeamViewer\*|*.tmp|RECURSE
FileKey2=%LocalAppData%\VirtualStore\Program Files*\TeamViewer\*|*.tmp|RECURSE
FileKey3=%ProgramFiles%\TeamViewer\Version9\Connections_incoming.txt
FileKey4=%AppData%\TeamViewer\Connections.txt
FileKey5=%AppData%\TeamViewer\MRU\RemoteSupport\*.tvc
FileKeys3 through 5 are missing | pipes and wont function properly.
[Tango]
ID=2399
LangSecRef=3022
DetectFile=%ProgramFiles%\Tango\Tango.exe
Default=True
FileKey1=%LocalAppData%\tango\call_log.dat
Same with FileKey1 here
[Wondershare Video Converter Ultimate]
ID=2376
LangSecRef=3023
Detect=HKLM\SOFTWARE\Wondershare\Wondershare Video Converter Ultimate
Default=True
FileKey1=%commonprogramfiles%\Wondershare\Wondershare Helper Compact\log\Data|*.*|RECURSE
FileKey2=%ProgramFiles%\Wondershare\Video Converter Ultimate\Log|*.*
FileKey3=%CommonAppData%\Wondershare Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\Wondershare Video Converter Ultimate\TempSiteIconDir
FileKey5=%CommonAppData%\Wondershare Video Converter Ultimate\TempThumbDir
FileKeys4 and 5 are missing deletion routines
Thanks Winapp2, will look into it ![:)]()
FYI - Tag&Rename 3.8.1 is generating reg entries as 3.7.
Interesting, then perhaps disregard that one, though I would imagine this indicates it supports 3.7 as well
