I just ran ccsetup528.exe, possibly downloaded from filehippo, and it behaved unlike any other ccleaner install I have previously used. Specifically, it ran for 20 minutes before I stopped the install. I suspect malware was scanning my Windows 7 system, but perhaps it was only strange but normal behavior.
Attached in Word format, is a doc with a screen shot of how the install program opened followed by a screenshot after 20 minutes with a slowly progressing scroll bar.
Is the behavior shown normal for ccsetup528.exe or is it malware??
Thanks for the reply/help, mta. I think I now know what happened.
I downloaded ccsetup528.exe direct from Piriform. When I ran it, it jumped to where I had left off, stopping my first install attempt. The scroll bar was 2/3rd across the screen, just where I had interrupted it because I feared malware. The installer claimed it was checking update. Well, I do not use Win 7 much and had just installed 284 updates. Evidently, ccsetup528.exe is literally checking each. That is why it was so slow. It is still not done, but I expect everything will be normal when it is finished.
My immediate guess was malware, but I guess if you do a lot of updates, like me, you get the result I got. I just have to wait until it finishes checking all the updates I just installed.
