Portable Questions / Help
Hi All-
Great program here THANKS I love it! I am using the regular version and now want to use the portable version which I downloaded to an SD card. I just have some questions even after doing a search on the forum.
Does anyone know how to force CCleaner to clean the portable version especially FireFox portable? it seems to clean my desktop version. I did check save to ini.
thanks
Yup, I definitely have the same problem like you.
CCleaner does have the capability to clean some custom folder. But of course it won't be the same.
You should edit the thread title, make things more clearer to other members. Or go to suggestion thread, and suggest this.
