Popup when cleaning (left side)
Hopefully, you can allow the popup that come out when CCLEANER is cleaning.
It is large, which is OK, but it is fixed so while cleaning, which might take time, it blocks some info on the screen.
Suggestion: add a "-" button to minimize the popup window.
Thanks
When registering, my email contained .com.lb (for Lebanon). It was refused. I had to use a gmail account.
Can you fix this?
