I have v2.01.507 running on XP SP2 and a 2.66MHz machine w/ 1GB Ram.
When selecting the "Run Cleaner" button, I get a popup indicating that one of my Network Storage Drive's Recycle Bins are corrupted. (It's not)
This started after I reinstalled everything on my new HD after a HD failure a couple weeks ago. I seem to recall I had this issue a couple years ago - but cannot remember how to correct it.
Thanks for the Kelly site. It is a very good site and I have seen it. I rebookmarked it.
As to my problem. As I was researching the fix I noticed I had a hidden folder called NPROTECT in the recycler folders of both network drives. Doh!!
That was my problem - leftover fuzz from Norton. NPROTECT is a program that allows a second chance to restore something deleted from the standard Windows Recycle Bin.
I never reinstalled Norton (long story and why I had to reinstall everything from scratch in the first place...) to my main computer so the my guess is the leftover NPROTECT exe was causing the problem.
I just forgot to remove NPROTECT from both network drive recycle bins. Oops!
After deleting both NPROTECTs, I ran CCleaner and all seems well.
