1.
Please give Analysis (and Cleaning) a better understanding of *
I am able to add to the CCleaner.ini (by notepad, and ALSO by CCleaner GUI) the line
Include04=PATH|C:\Program Files\LogMeIn\|dbg*.*.txt
Unfortunately Analysis ignores it,
and I have not dared test cleansing incase it scrubs the whole directory.
Consequently for multiple junk files I need multiple lines of "Include..."
2.
Please permit environmental variables such as %APPDATA%
A large amount of ADOBE / MACROMEDIA / FLASH RUBBISH is taken out by
Include08=PATH|C:\Documents and Settings\Dad\Application Data\Macromedia\Flash Player\|*.*
Twice as much is taken out by
Include09=PATH|C:\Documents and Settings\Suzanne\Application Data\Macromedia\Flash Player\|*.*
Please note that "Include08=..." can be stipulated by either a Notepad Edit of the CCleaner GUI,
but because I have no access to my daughter's profile I cannot use the CCleaner GUI to go beyond
and that would cause her much grief ( and I would also suffer consequences ).
Please note that with portable CCleaner I have the ability with Notepad to stipulate cleansing in a profile to which I have no access.
Were I using the non-portable version I guess I would have to use Regedit to adjust her private registry.
I am sure I could change her password and gain access,
but that would violate her privacy, and I would not be able to put it back to conceal my violation.
An infinitely superior solution would be
Include08=PATH|%APPDATA%\Macromedia\Flash Player\|*.*
With only one "IncludeNN=..." line every profile would be cleansed when active,
i.e. 1 line would purge twice as much junk whilst I have 1 daughter,
and would purge 100 times as much if my wife added another 99 children to the family ! !
Unfortunately this %APPDATA% not only fails to clean my daughter's profile
it also fails to clean my own profile.
Use of a single Include would save me a lot of typing,
and it would allow CCleaner to focus upon cleaning the active profile,
and avoid wasting time on the multiple ( 100 ? ) profiles not currently accessible.
Regards
Alan
