Please help...
I do apologise if my post is into wrong section/place.
I bought CCleaner Professional for my WIndows PC.
I have a question. That soon after I close any browser. Then I want to see a window that shows you that CCleaner cleaned the browser soon after I exit it.
There are a window that appear soon after you close any browser.
How to active this function?
Sorry for my poor english.
This used to work but on mine it hasn’t for some time, if you have another program open at the time & close Edge then the pop-up does appear.
It should be enabled within settings, look for clean with notification.
