Please help!
Sorry to post this here, but the CCleaner and Piriform Contact Us support forms DONT WORK!!!!!!!
Please fix this guys!, or, if you have an e-mail address from Piriform to which I could e-mail this, tell me. donate@piriform.com doesn't work.......
Hi. I donated to Piriform Ltd through paypal, in order to receive the benefit of having newer versions of CCleaner sent to my e-mail.
However, I never received an e-mail of confirmation, or, an e-mail with the latest version that is 2.21.940 before it was posted on the website, like the donation policy specifies.
Please, resolve this issue, and, I would like to report an other minor issue in CCleaner. Under the Tools and uninstaller section, where the uninstallers for all the PC's software are listed, when CCleaner starts displaying the install dates info, the Size column glitches as in like moving to the right and left.
I am running Vista Home Premium SP2 32-bit, all updates installed through windows update.
Thank you!
Also, the Contact form that is linked to on the CCleaner website http://www.ccleaner.com/contact doesn't work, neither does the one on the Piriform website, giving a Server Error in '/' Application. error.
Here is what the error displays in Mozilla 3.0.11
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
<system.web>
<customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
</system.web>
</configuration>
Welcome to the Forums :)
I can't help with the donation part.
But, can you explain the glitch? I haven't had any problem SO FAR.
