Please help for Mobo Soyo 4SAW (yes, 1997)
I can?t find internet sites with this info. All I got was Bios Update.
Does anybody know some usefull link ?
Thanks a lot. Angel
Have you tried here?
http://www.motherboard.cz/driver/soyo.htm
Yes, I did, but it is not there. Many Thanks to Larry, anyway.
Haven't a clue really if this is even the right one
http://stason.org/TULARC/pc/motherboards/S...-4SAW-2-W5.html
bios updates are on the SOYO.COM.TW website.
what do you want to find in the manual ?
jumpers & layout are here:
as for drivers, which component do you need drivers for? If you're installing Windows 9x or something, the motherboard hardware should be supported out of the box.
