Ok, Ive finally saved up enough to fix the Dell I broke a while back. The processor will be a Celeron D 2.6GHZ, a 1GB stick of PC2700 ram, and am thinking of getting a geforce 6600 for it...Specs for it can be found here:http://www.buyxg.com/store/item.asp?key=VC-135-216
It says "BUS PCI-e x 16", to my understanding that is the PCI speed, I was wondering if that meant my pc would have to be "BUS PCI-e x 16"...Ive tried to find out what my "pci speed" is on my Dell but I cant seem to find it anywhere, would that be compatible with the Dell Dimension 2400 that I have?
Thanks alot,
Supaflies
BTW:If your curious about my other products that I will be buying, you can find the ram here:http://www.digi4me.com/product.php?productid=462
And the Processor here:http://www.starmicro.net/detail.aspx?ID=48
Thanks alot,
Supaflies
Just found out that PCIE is not compatible with my system, so Im going with the Geforce FX5700LE, which you can see here:http://www2.newegg.com/Product/Product.asp?Item=14-139-166&depa=1.
