PC reset
Hi to all. i'm new here and i need help....
Using CC to clean my registry result in a computer reset. I'm very surprise because I use CC from years.
So i decide to check with regedit all the key searching for error and two keys say can't delete them or rename or do anything.
What can i do? Is there a way to correct that keys?
Sorry to say that I have tryed other software and all with the same result: computer reset.
If I can't correct the keys ( and say thanks to MS.....) can CC bypass them?
Sorry to bore or post in the incorrect place..... please help....
I'm using XP SP3
