?" Your PC felling under water. Make it better. Your PC is fixed now. Start again Your PC is felling under water. Make it better.".............. You can do it hundred times and your PC is going to be "under water" forever.?
30 minutes ago, Ondrej Scheuch said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> <span class="ipsEmoji">?</span>" Your PC felling under water. Make it better. Your PC is fixed now. Start again Your PC is felling under water. Make it better.".............. You can do it hundred times and your PC is going to be "under water" forever.<span class="ipsEmoji">?</span></p> </div>
Is this what you are talking about? ''Your PC feels under the weather'' ?
https://community.ccleaner.com/topic/61305-false-positives-or-not/#comment-332325
