partitions not showing up
Not sure if where to post this.
Defraggler v2.01.239 (21 Dec 2010)
I have separate partitions set off for my hard drive, for my program and program 86x folders, well most programs are in the hard drive some are in the one with the main OS, i have set it up this way because im getting a 120gb ssd. the partions are mounted to empty ntfs folders
C:\Program Files (x86)\games-apps(**this is the empty ntfs folder,all files are put in here just like its on the normal harddrive)
C:\Program Files\games-apps(***^same note)
is there a way to defrag these, it dosnt do anything if i click on to defrag folder and click the mounted drive, but i don't really want to defrag each folder separately eather
