Outlook problem
Ran CCleaner on my xp SP# samsung Q30
Has speeded up but i asked it to remove windows live messenger and now outlook opens and then closes with message "Cannot start Microsoft Office outlook.Unable to open the outlook window.The set of folders could not be opened" I then tried tu use restore files to retore changes but they will not "merge" dialog box says Cannot import....some keysare open by the system or other processes
Have tried repairinfg then reinstalling outlook but no result
Any ideas to help
Thanks
Any ideas to help
Thanks
Hi Steve,
I take it you mean that you used the Registry Issues function.
Close everything and then open Explorer to My Documents and try "Merge" again.
Please remember to "Merge" backups in the reverse order.
Backup file 3,then 2 then 1.
If you didn't change the names they will have a time stamp in the name.
Good luck,
:) davey
P.S. Things like Windows live Messenger can be just turned off. Either in Services or use Start > Set Program access and defaults > Add Remove Windows Components.
Leave the Registry to the "specialists". Play with fire and you will get burned. (Brotherly advice)
If the above does not work then try doing it in Safe Mode.
Safe Mode Boot Safe boot XP
http://support.microsoft.com/kb/315222/en-us
