Hi i have a problem with my mac after in stalling ccleaner, I never had problems with my macbookpro (2 years "big thumps up"), after download tha program ccleaner and use it. at first it works great the first of minutes(the fan drops more than 1500 rps from 3200 rpm > -/+ 1700 rps) than i close the the osx 10.6.8 and it will not com up again .. it ends bij the apple logo and a small time strip after this (30sec) ist goes out (power off automaticly). over en over again. does somewne has the same problem. i hope someone knows a solution.
I have used only the standaard preset.
Moved to MAC Board
Sadly we don't have any regular MAC users who come around and can help, The developers do read all threads so they may come by and reply.
I guess this won't be of much use to you but if your Mac is doing a reset loop then you are going to have to reinstall from scratch. You can't even get to the time machine options? One of the things about Macs is that they can get rid of programmes very easily but they do leave bits behind. I think your only solution may be to contact the Mac Support and see what they suggest. I don't even know if there is a Mac version of 'safe mode' and I've been using Macs for years!
