Options for Recovery or Logging events
Hi, I am new to CCleaner, and I have few questions:
1. Is there any way to restore/recover files cleaned by CCleaner?
2. Does CCleaner maintain any log of the files which it has deleted?
3. When you wipe free space using CCleaner does it also wipe the MFT records of the files?
4. Will I be able to know what was the last execution date & time of CCleaner?
1) Not within CC
2) No, unless you capture a text copy of the content to be deleted
3) Yes if you're using the Drive Wiper, no if you're using Options/Settings - unless you specifically request it
4) Probably in the registry somewhere, but I've never bothered to look, so at least a not very easily
