Detailed log of cleaned IE anf Ff temporary files keeps appearing even though I have unchecked those settings under Options Advanced.
How can I correct this?
Same here. Wonder if is a new bug...
Thanks for your quick reply. I have reported it as a bug and mentioned (I hope you don't mind) that you are having the same problem.
