Hi, sometimes I use ccleaner just to clean the registry, and if i put the file winapp2.ini in the ccleaner directory it takes too long to start (100% CPU for a while).
I know about trim.bat to trims the entries from the full Winapp2.ini.
But it would be a very good, and time saving idea to put an option to load manually the winapp2.ini or automatically.
Thanks a lot for your atention and for this program.
Or ZIP it. Then delete when you don't want it, and unzip when you need it. You could also use a batch (.bat) or script file to rename it on the fly so that it isn't usable by CCleaner, i.e.; winapp2.disable
Thanks for your answers, some of the tips I already know. And some not: Thanks for the F5 tip.
The solution I use is to have 2 copies of ccleaner, one with the file winapp2.ini and the other without it.
My sugestion is to put an option to load manually a winapp2.ini. You can have some custom winapp2_xx.ini files and load them when you need. And/Or an option to load or not load automatically a winapp2.ini file in ccleaner directory.
Doing this, winapp2.ini developers could have the option to make customs winapp2.ini files: system, games, browsers, ....
Also, in some computers, starting ccleaner with winapp2.ini can take more than 1 minute of 100% CPU usage.
So I think it would be a time saver, energy saver, cpu fan saver putting those options.
