If you know the location of the stuff you want cleaning, then I would suggest using CCleaners "Include" feature to clean them until Opera 10 is out of it's Alpha and Beta stages.
CCleaner\Options\Include Add File or Add Folder, and check the "Custom Files And Folders" box in the Advanced section.
