Speccy v 1.04.173 will not initialize any data on the opening page.
Each line reports...
' The directory,Filename or Volume label syntax is incorrect.'
(see attached)
What are the dependancies for the app to solve this matter? (Java, .NET , system config etc...)
This is a VM workstation 7x session running 2003 server SP2. This is the only instance that is causing trouble. Other similiar instances report OK so its local to this vm.
Any direction is helpful to start troubleshooting as I have no clues yet.
Thanks
