There is problem with the notifications from this forum. This problem has surfaced since the latest CCleaner forum software was installed.
- When I receive an email notification for a new post or or for a new Private Message then I receive only 1 email. But I also receive every now & then an email called "Your CCleaner Community Forums digest" and every "digest" Iis received by me twice (when sent).
- No, I didn't change any settings for the notifications after the last forum software was installed. So, it could be that the forum gets "confused" by the old settings.
Below a picture of the emails I received today in my emailprogram (Outlook Express Classic) from the CCleaner forum. I received this ".......... Forum Digest" twice. While I receiveother notification email(s) only once. The good folks here at CCleaner should investigate why this happens only in this particular situation.
- It seems the problem (as described above) has been solved. Only a few minutes ago I received another "Forum digest" notification email but this time I received this email only once. I will keep an eye on this problem to see if this problem REALLY been solved.
- By posting this message I expect to receive another "Forum Digest" tomorrow. If tomorrow I receive only 1 "Forum digest" then I think I can safely assume that the problem has been solved for good. Other visitors of this forum will also benefit from this forum software improvement / fix / tweak / ..........
- I thought there were more people who had the same problem. But perhaps those people / visitors didn't report the odd behaviour ? I don't know.
- I don't think I want to blame my email setup or email program. Yes, there was a recent update for my emailprogram but I installed that update before I started this thread.
- And I didn't change any of the settings in my email program in the last say week. No, all things considered I do think the folks here at CCleaner.com "tweaked" the forum software (a little bit). Just enough to make the problem go away.
- It certainly seems that the double notifications problem has been fixed. In that regard posting this problem in this sub-forum has helped to fix the problem.
