Not working on Android 16 QPR Beta
Ever since updating to the Android 16 QPR beta on my Google Pixel 8 Pro, the cleaning process is no longer working properly, most of the app caches aren’t being cleaned with it failing each time. The process is also taking at least twice as long as normal.
Is this a known bug? I’m rooted and have correctly granted all permissions, have tried clearing the cache and data of the CC app as well as uninstalling and reinstalling but still the same issue.
Beta versions of anything are incomplete and as such bugs may be expected.
It’s the Android beta that is buggy, you cannot expect any apps to work properly with Android betas - some will, some won’t.
Apps are designed to work with “offically released” versions not with Betas.
