ccleaner v5.41.6446 professional is NOT working in SAFE MODE.
exit when it reach 100%
sorry for my bad english.
thx.
thx.
What operating system are you using?
2 hours ago, hazelnut said:<div class="ipsQuote_contents"> <p> What operating system are you using? </p> </div>
windows 7
What happens when you run it in ordinary mode, does it do the same thing?
36 minutes ago, hazelnut said:<div class="ipsQuote_contents"> <p> What happens when you run it in ordinary mode, does it do the same thing? </p> </div>
no
Are you using safe mode or safe mode with networking?
11 hours ago, hazelnut said:<div class="ipsQuote_contents"> <p> Are you using safe mode or safe mode with networking? </p> </div>
SAFE MODE ONLY
hello
I have pointed devs to your thread.
Why you running it in safemode? The only purpose in running things in safe mode is when the malware is stopping programs from running in regular mode. You are experience odd behavior for the whole point of SF. Malware cant be completed loaded into memory .
The amount of times we see members suggesting run MBAM is shocking. It's an option that can be used if all else fails. A Bad option. MBAM relies on runtime files in the net library. The same as CCleaners c++ uses libs.</span></span>
a lot of people reboot their PC’s into Safe Mode when performing maintainance tasks to have no interferrance from other services, like AV for instrance.
I don’t see a problem with that idea, and as you state, we regularly suggest that to get users over a hurdle.
(although I don’t think we suggest running MBAM because of Rule #10)
And? CCleaner also disables reg items via startup like MSCONFIG does. But that does not mean it should ever be done.
same problem even after updating ccleaner to the latest cersion , please help. i gave you long and enough time to solve the problem and nothing happened.i love ccleaner i'm trying to not replacing it with another software. ask me anything you want even if you wanna enter my pc and fix it.
ccleaner pro v5.43.6522
win7 ultimate
I am running Windows 7 Home Premium. I have CCleaner Free v5.43.6522 (64-bit).
I just tried running the cleaner in safe mode, and I too, experienced a program exit, after running the cleaner analysis.
CCleaner cleaner runs fine in normal mode.
Registry cleaner runs fine in normal and safe mode.
I see you had tried v.51 and now v5.43 - could I suggest reverting to v5.40 and seeing if that helps.
I only ask because, for me, that was the last version that I felt 'just worked'.
I have been told by an Admin that v5.40 has 'critical bugs' but haven't they all recently !!! <img alt=":P" data-emoticon="" height="20" src="<fileStore.core_Emoticons>/emoticons/default_tongue.png" srcset="<fileStore.core_Emoticons>/emoticons/tongue@2x.png 2x" title=":P" width="20"> despite that, it still remains a solid performer for me.
as previously stated, we (Moderators) have posted this thread to a reserved area where Admins regularly log on to view issues - sadly that is all we can do.
i have it tryed for a few minutes and
yes -> in safe mode ccleaner v5.43.6522 closes itself without permission after analyze or run reached with 100%
w8.1 64 bit
I know this is a very old topic, but just wanted to report that this bug is STILL present in CCleaner v5.61... with Windows booted in safe mode, CCleaner will always auto close when analysis stage reaches 100%. No problems when booted in normal mode using the same cleaning settings / options. Tested in 2 different PCs with Windows 8.1 x64 and Windows 10 1903 x64, same behavior.
A system cleanup / maintenance software that can't be run in safe mode? This is absurd. If at least the auto close happened only after the cleanup procedure, it wouldn't be so serious, just an annoyance - but as it is, this is a serious functionality-impairing bug. Please Avast/Piriform, get around to fixing this.
After some further testing - turns out that if I boot into "safe mode with networking", CCleaner works normally. The bug only happens in standard safe mode (without networking).
Still, having network enabled shouldn't be a requirement to use CCleaner in safe mode.
Maybe it wants to phone home to work, check license server, etc. I know another software Malwarebytes complains an absurd amount of times on-screen if it can't phone home during a scan to contact the license server -- or at least it used to in v3.x.
