roosta
14 September 2015 18:24
1
I unfortunately plugged my external drive to a NAS device and the NAS formatted the drive...
So I started Recuva free and it worked for three days and 4 seconds before the end, Windows said that Recuva is not working anymore.
There are (were) about 190.000 mp3s on my drive.
Any suggestions?
Thanks
roosta
PS: Windows 10, i870, 8 GB RAM
mta
14 September 2015 22:08
2
in case it helps others, what sort of NAS unit is it?
did you plug your external drive into it internally or via USB?
do you know what sort of format occured?
what worked for 3 days, the Recuva scan or the file recovery?
what happens now when you re-run Recuva?
roosta
15 September 2015 17:22
4
I would like to post a screenshot here. How can I insert a picture?
With "My media" it does not work...
Press the More Reply Options button to upload a jpg, png or gif from your machine
roosta
17 September 2015 06:34
9
Recuva recovered about 45.000 mp3s!
Thanks for this great software and forum.
roosta
Glad to hear everything worked for you roosta
