Not possible to download and install Recuva portable
I tried to download the portable version Recuva 1.5.3 for Windows.
On your homepage
https://www.ccleaner.com/recuva/features/portable-version
you write:
"For the portable version, simply go to /recuva/download/portable and download the .ZIP file."
The inscripted link <a href="https://www.ccleaner.com/recuva/download/portable/" rel="external">https://www.ccleaner.com/recuva/download/portable/</a> leads not to a download page for the zip file but to the site
https://www.ccleaner.com/recuva/download/standard
with the text:
T"hank you for downloading Recuva
Follow these 3 simple steps to complete your Recuva installation"
and it asks for the download of rcsetup153.exe.
Please tell me where I can download the zip file for the portable version for Windows 10.
Thanks for useful help
Dr.med. Joachim Elz-Fianda
The portable versions of Recuva, Defraggler, and Speccy have been unavailable for a number of months now.
We've asked the staff but haven't had an answer as to why they have gone missing, or if/when they will be back.
Quote
<div class="ipsQuote_contents" data-gramm="false">
Quote
by the way... in the meantime
perhaps download it from the german [non piriform site] ? recuva v1.53 (zip)
take the link and paste it in the browser - address - bar
[Link Removed]
@trium please don't post non piriform/file hippo links. Anywhere else could be dangerous and does break the user license
I found a solution here in this forum.
I succeded in opening the rcsetup153.exe with 7Zip and to extract ist in a directory on an USB stick. The unpacked direectory contains the files recuva64.exe and recuva.exe. The first one runs without error.
So far and thanks to this forum
Greetings from Germany
Dr.Mabuse
Hi,
You can try this one.
  1. Install the free version of Recuva using this link https://www.ccleaner.com/recuva/download/standard Once the download has completed, simply double-click the file to start the installation.
  2. Create a folder on a USB drive and name it anything that you would like. (e.g. Recuva Pro Portable)
  3. Browse to the program's installation folder (e.g. C:\Program Files\Recuva) and copy its files to the folder you created.
  4. Create a portable.dat dummy file inside of the folder you created.
To create the portable.dat dummy file:
- Right-click on a blank area of the new folder > click New > Text Document
- Replace the entire file name with "portable.dat" and click Enter.
- You will be prompted to confirm the file extension change. Click Yes.
On 21/03/2020 at 18:58, DrMabuse said:
		Dr.Mabuse
		Hi,
	<ol style="border:0px;color:#2f3941;font-size:14px;padding:0px 15px;vertical-align:baseline;"><li style="border:0px;font-size:14px;padding:0px;vertical-align:baseline;">
			Install the free version of Recuva using this link<span> </span><a href="https://www.ccleaner.com/recuva/download/standard" rel="external" style="color:#1f73b7;font-size:14px;padding:0px;vertical-align:baseline;">https://www.ccleaner.com/recuva/download/standard</a><span> </span>Once the download has completed, simply double-click the file to start the installation.
		</li>
		</li>
		</li>
		</li>
	</ol><p>
		<span style="background-color:#ffffff;color:#2f3941;font-size:14px;">To create the portable.dat dummy file: </span><br style="background-color:#ffffff;color:#2f3941;font-size:14px;" /><span style="background-color:#ffffff;color:#2f3941;font-size:14px;">- Right-click on a blank area of the new folder &gt; click New &gt; Text Document </span><br style="background-color:#ffffff;color:#2f3941;font-size:14px;" /><span style="background-color:#ffffff;color:#2f3941;font-size:14px;">- Replace the entire file name with "portable.dat" and click Enter. </span><br style="background-color:#ffffff;color:#2f3941;font-size:14px;" /><span style="background-color:#ffffff;color:#2f3941;font-size:14px;">- You will be prompted to confirm the file extension change. Click Yes.</span>
Just to let everyone know, neither of the above techniques will successfully create the most recent portable version of Recuva that was officially released.
The official portable Recuva release of v1.53.0.1087 was just 4,956,888 bytes for the 64-bit executable.
The current non-portable Recuva release of v1.53.0.1087 weighs in at a hefty 5,609,656 bytes for the 64-bit executable. That's over a half a megabyte of unnecessary additional closed-source code doing who-knows-what.
When you try either of the above techniques, you will get the bloated release, and not the true portable version.
Hopefully, someday, a real person from Piriform/Avast will come to this forum and let us all know that a real portable version is available again. Until then, I cannot recommend Recuva to others.
23 hours ago, Pearform said:
That's because the "portable.dat" dummy file mentioned above your post is not complete. It has to have this, and only this inside it, and then save it:
#PORTABLE#
		#PORTABLE#
		<a class="ipsAttachLink ipsAttachLink_image" href="<fileStore.core_Attachment>/monthly_2020_09/portable_dot_dat.png.e16d3841f8feccb7a96bb3b092782fb0.png" data-fileid="13911" data-fileext="png" rel=""><img alt="portable_dot_dat.png" class="ipsImage ipsImage_thumbnailed" data-fileid="13911" data-ratio="39.09" width="463" src="<fileStore.core_Attachment>/monthly_2020_09/portable_dot_dat.png.e16d3841f8feccb7a96bb3b092782fb0.png" /></a>
Good point, but as I mentioned, the executable files are very different too. Any chance of getting the actual portable release of Recuva available via official channels again?
