So, I just got defraggler about a week ago and worked perfectly on my external (F:\) and partitoned drive (D:\) but when I used it on my main drive with vista on (C:\) it only defragged some of the files and left some major ones fragmented! I checked the ledgend and saw those files were not unmovable so i tried again, yet it said "no files were defragmented."
Does anyone know why this 9.2GB of files wont defrag?
How can you tell? Defraggler doesn't mark unmovable files as such. The hibernation file, metadata, system files are just shown as "normal" files and are simply left out of defragmentation.
I also would appreciate to have them marked as "unmovable".
I tried at a Windows XP computer, and the problem does not appear. It is only for Win Vista.
I guess I've got a short cut to get over this: copy the exe defraggler file to a pen drive and start the defraggler from the pen drive instead of from the HD. I noticed that if you do so all files will be defragmented.
I have checked the fragmented file list and i didnt see the "hibernation file" or any "metadata", but thanks for trying.
