Not Defragging 100%
I hope I can word this correctly
I am running W7 32bit
It is a home computer
I Defrag once a week.
I have defrag it sometimes up to 6 times to bring it back to a 0%
I am update?
Should I uninstall and reinstall the program
My Security is Kaspersky and that is up to date.
When I download a program I always put Kaspersky into "Pause"
Your help would be greatly appreciated
Keith
Follow these instructions.
:ballot_box_with_check: Tick these 3 boxes dep56p.png and defrag.
kroozer
Thank you very much I have done all that and I will run the defrag later today.
Keith :rolleyes: :rolleyes:
Now I am completely confused .
I did exactly what you told me to do and double checked it
This are the results
I only see one line Top line of the "squares" graph now instead of all of it.
Fragmented Files 56
Total Fragments 192
After the Defrag
FF 49
TF 177
0%
Turn off and a restart
FF 77
TF 190
Where did all they come from
In the files there is a huge list
What do I do now?
Keith
Analyze, click on the File list tab, right click and Save List to Text File.
Delete any sensitive information, copy the list and place in the code box, and post. snips.png
Kroozer
I have no idea what you are talking about sorry.
Analyze, Where do I find that ?
File list tab, Where is that
Save List to Text File. Same again
Delete any sensitive information, copy the list and place in the code box, and post. Same again
<> I cannot find that either.
Remember I am using W7 32bit
Keith
Instead of defragging the whole drive I defrag only the files. 5423a.png It's very fast.
Just tick ☑Filename and defrag.
The result is always zero frag and an empty list. Try it. If afterward you still have a list and wish to post it, these images will guide you.
Only if your list is very long, please use the code box <> in the forum Reply to this topic panel to conserve space. snips.png If the list is short don't bother with the code box. :)
Fragmented Files 56
Total Fragments 192
After the Defrag
FF 49
TF 177
0%
FF 77
TF 190
What do I do now?
Keith
you answered your own question "where did they all come from" with "turn off and a restart"
windows is like a messy child, defragging is cleaning up for the child, the second you are done (and often while you do) the child starts to play and leaves things places.
you are fretting over a small irrelevant difference between 49/177 and 77/190
Nergal
I think you have solved the problem "dont worry about it"
That is exactly what I will do.
Thank you all
Keith
Posts deleted.
Please don't re-open a 3 year old thread with a post that has no relevance to it now.
