Not cleanint TEMP directory on second hard drive
First off , this is an excellent product.
I installed a second hard drive and moved my windows TEMP directory to the new drive. CCleaner doesn't clean up files in the new temp diretory. I have the enviroment variable TMP and TEMP set to the new drive
You can add that temp directory to 'Custom Files and Folders' by clicking in CCleaner: Options > Custom > Add Folder
But please note doing so will not respect the 48 hour rule of deleting temp files.
I guess CCleaner determines the temporary file folder by using the %TMP% or %TEMP% environmental variable.
I suppose and the variables can be confirmed or changed by:
Right click My Computer select Properties > Advanced > Environment Variables
My question is related. I have two hard drives, C & G. When I ran the Ccleaner, it only did the C drive. How do I get it to do the G drive too?
tandalatom
I thought Ccleaner only worked on the drive it is installed on
tandalatom
As far as I know, the operating system can only have one temporary folder. The temporary folder is defined in the %TMP% and %TEMP% environment variables. The other temp folder you have on G: might not be a *real* temp folder.
Hi all,
i keep my Temp (i mean "Temporary Internet Files") on the D: partition, and
all works fine, with CCleaner installed on C: partition (same phisical hard disk)
I uninstalled , then re-installed and it now cleans my temp directory on the j:\ drive. It must identify the temp directory at install time.
