not cleaning
ccleaner not cleaning system temporary files please fix it cause i delete the files by myself :(:angry:
Which particular system temp files is it not cleaning?
Which build and version of ccleaner are you using?
Which operating system do you have?
Are you a new user of ccleaner?
Do you have Options > Advanced > 'Only delete files in Windows Temp folders older than 48 hours' selected?
tried what glen said didnt work
its not cleaning the temp in the computer just like you run stuff
im using the latest version 2.23.999
im using xp
im an old user
From hazels post #2 above.
You need to be more specific. Which files or the location of the aforementioned files.
