not cleaning
For the first several months of using CCleaner all files found in analyse were reported cleaned, but for the past month or so some of the files are not cleaned. It varies considerably, this morning for example 129 megs were found, but only 12 were c.leaned. Usually about half the found files are cleaned. After cleaning a second analyse finds no files to be cleaned.
