Not cleaning new Waterfox v55.1.0.1
The new Waterfox v55.1.0.1 has changes the folder for its profile and data.
Profile folders was in AppData/Roaming/Mozilla/Firefox is now moved to:
AppData\Roaming\Waterfox\Profiles
Application still lists FireFox...
Do you have any firefox on there other than waterfox? If not then it's already detecting it; browsers are cleaned by their parent browser's heading.
You also may need to set customlocation
See http://www.piriform.com/docs/ccleaner/advanced-usage/ccleaner-ini-files/how-to-clean-user-data-from-non-standard-mozilla-browsers
Upgraded to 5.36.6278 - still no fix for Waterfox browser.
Suggested thread to "to set customlocation" was not clean as to where the "ccleaner.ini" was..
Waterfox v55.2.2
Ccleaner.ini is made by options. The setting is save preferences in ini (I think it's in the first options screen but if not then it's under advanced). At that point you can find the file in your ccleaner folder (usually c:\program files\ccleaner unless you changed that on install)
Okay found it: Options / Advanced - check box "Save all settings to INI file
Yes now at "C:\Program Files\CCleaner".
My system has the "User" folders on the D: drive.
I added the following to the ccleaner.ini:
CustomLocation1=FIREFOX|d:\Users\DAR\AppData\Roaming\Waterfox\Profiles\pi5j6e2f.default
CustomLocation2=FIREFOX|d:\Users\DAR\AppData\Local\Waterfox\Profiles\pi5j6e2f.default\cache2
Note: tried using "%APPDATA%" tag but did not work for me.
Did a "Analyze" and it now showed Cookie and Cache from Waterfox
Hope this helps...
%appdata% is a system variable that points to C:\ drive, so that wouldn't work since you have moved your User location to D:\ drive.
start a commend prompt and type in echo %appdata% to see what it is set to.
Yes it is a system variable. I ran a cmd and did the echo - I got: "d:\Users\DAR\AppData\Roaming".
I was trying to not use a direct folder reference in what I did to get Waterfox cleaned.
well, bugger me, substituting d:\Users\DAR\AppData\Roaming for %appdata% should work then. (but not for CustomLocation2)
I got %APPDATA% to work for cookies, but the system tag of %LOCALAPPDATA% for the location of the cache did not.
// Waterfox cookies
CustomLocation1=FIREFOX|%APPDATA%\Waterfox\Profiles\pi5j6e2f.default
// Waterfox Cache
CustomLocation2=FIREFOX|%LOCALAPPDATA%\Waterfox\Profiles\pi5j6e2f.default
hmmm, sorry, no answer for that.
