Not cleaning clipboard for common manufacturer extended clipboards
Many common Android devices include extended clipboards that are integrated into the manufacturer's software.
For example, most LG devices include an extended clipboard that can hold multiple entries.
When CCleaner for Android attempts to clean these clipboards, it fails. None of the entries (not even the most recent one) is cleaned.
Can you fix this?
Bump
Is this the correct place to post this issue? I'm disappointed that Piriform has chosen to not respond at all for over 3 months.
Well, it's been over 4 months, and no reply from anyone at Piriform. It appears that no one from Piriform actually reads their own forum. That's unfortunate, especially since they designate this forum as the place to "Post bug reports, suggestions and questions about CCleaner for Android".
Is Piriform about to go out of business? I can't think of any other reasonable explanation as to why they would ignore their own customers.
Hi Pearform,
I'm sorry that nobody has got back to you about this.
CCleaner Android is able to clean the standard clipboard however the extended clipboards aren't part of this functionality. It's possible that they may be added in the future, but right now it's only the standard clipboards that are cleaned.
