Not cleaning all files?
During the past few months, I have noticed that CC finds about 1400 mb of junk..but when I go to run cleaner...it only gets rid of less than 100 MB...
any ideas what I'm...or CC is doing wrong?
Hello pwrslider,
I suspect that all necessary files are being cleaned.For some members the figures don't print properly.Use v2.05.555 CCleaner please.
Please provide more info.
What OS and version.Browsers,Security apps ,CCleaner version do you use?
It may not be you or CCleaner.You may have some corrupted files or some other special circumstances.
Do you have OPTIONS > ADVANCED option boxes checked to print detail listings?
These may help you see which files are not being deleted.These files may be unusually large.
Do you use the Include or Exclude options for anything?
You may have to try cleaning one option at a time to find where this difference is occurring.
Do you use any Regional Settings that are possibly incorrect?
1400 MB is an awful lot to be cleaned for someone who uses CCleaner regularly.
Do you save an inordinate amount of cookies?
What size do you specify for IE cache?
As you can see your situation is unusual and requires unusual methods to find the problem.
Best Wishes,
:) davey
