not able to rebuilt cleaned registry
hello togher
i`ve got the following problem with the ccleaner v.2.27.1070
on an vista home premium sp2 system:
I have cleaned my registry by using ccleaner v.2.27.1070 and generated an security copie of it.
Habe eben meine registry bereinigt und eine sicherheitskopie mit cclean erstellt.
after restarting my system my windows explorer is collabsing when wenn i?m using the serch funktion behind the startbutton . this is only happening when i enter only the letter " c " . :blink:
I`ve tried to recover my the registry with the security copy of it but it does not work.
My system gives out the following message :
dataname.reg can not be imported: failure by acces to registry.
I need Help!!
thanks!!
Import it in safe mode
