First time use of Defraggler. After about 90 mins. the error message "Encountered problem, must close" , Debug / Close.
Any solutions? and would it have defragmented up to that time?
Hi bubbles.
If you'd started the defrag process as opposed to "Analyze", it would have been defragging. Defraggler is written to cope with power outages or system crashes so that shouldn't cause you any problems.
http://www.piriform.com/docs/defraggler/technical-information/why-defraggler-is-safe-to-use
Can you run Defraggler in "Debug Mode" and post the log here for the devs.
http://www.piriform.com/docs/defraggler/troubleshooting/running-defraggler-in-debug-mode
Thanks.
