Just downloaded and ran the analyze. Looks like it wants to get rid of my symantec antivirus (416 files) and some files from my steam account. Am I supposed to just agree to everything it wants?
Also, will be looking for help on cleanup of the startup programs as I have a LOT running when I start even before I open anything.
Thanks
Steam cleaning, might efftect your games, so go through and make sure
Symantec Cleaning should be fine, it's supposed to be just old Virus def downloads (what is downloaded then applied, thus no longer needed) and logs.
As long as you aren't using CCleanerEnhanced or Winapp2.ini files the following is what is cleaned
[steam]
ID=2203
LangSecRef=3023
DetectFile=%ProgramFiles%\Steam\Steam.exe
Default=True
FileKey1=%ProgramFiles%\Steam|*.mdmp
FileKey2=%ProgramFiles%\Steam\Dumps|*.*|RECURSE
FileKey3=%ProgramFiles%\Steam|*.log
FileKey4=%ProgramFiles%\Steam\Logs|*.*|RECURSE
[Norton AntiVirus]
ID=2060
LangSecRef=3024
Detect=HKLM\SOFTWARE\Symantec\Norton AntiVirus NT\Install\7.50
Default=True
FileKey1=%commonappdata%\Symantec\Norton AntiVirus Corporate Edition\7.5\Logs|*.log
FileKey2=%localappdata%\Symantec\Norton AntiVirus Corporate Edition\7.5\Logs|*.log
FileKey3=%commonappdata%\Symantec\LiveUpdate\Downloads|*.*
[symantec AntiVirus]
ID=2061
LangSecRef=3024
Detect=HKLM\SOFTWARE\Symantec\Symantec AntiVirus\Install\7.50
Default=True
FileKey1=%commonappdata%\Symantec\Symantec AntiVirus Corporate Edition\7.5\Logs|.log
FileKey2=%localappdata%\Symantec\Symantec AntiVirus Corporate Edition\7.5\Logs|.log
FileKey3=%commonappdata%\Symantec\LiveUpdate\Downloads|.
Thanks for the input. I'll let it finish up and hopefully all will be well.
