Network Management Console
I run CCleaner utilizing Active Directory for my computers. In the listing it will list the computer name only. Is it possible for it to display the computer description as well? This displays the computer users name which makes it much easier. I can go into and edit host information but as soon as you reload the active directory it reverts back to the computer name.
Thanks in advance,
Sean
Are you using ccleaner network version? Is this a business location?
Yes I am using the Network version at a business.
In that case you should contact directly the support team. The forum users aren't usually paid version users, and you get priority support as a purchaser
http://www.piriform.com/support
