Had to restore my Pc today as MS Updates nuked it. About a month to two months ago I installed a little program that changed the cursor to blue, then green, to red etc. as it was opening files/programs. I can't remember its name and I did search but can't find any hits for exactly what I'm looking for. Hazelnut usually comes through with this stuff! lol Thank You!
CursorFX???
Do you use Sandboxie slowday?
CursorFX???
Thanks but that isn't it.
Yes I was aware of it and had updated Sb. I think Comodo time Machine was the problem, even though it also saved me. I guess that ...83 update goes to the kernel level and that is the problem. I'm all updated now with the exception of that one.
was i along the right lines though of you wanting cursor effects?
Yes! I'll search freeware files, majorgeeks, pcworld or how-to geeks sites. Had to have become aware of it there.
The light bulb came on! I remembered I had it installed on the laptop so I booted it! Thanks for trying to help.
http://tinyhacker.com/hacks/beautiful-xsx-...lended-cursors/
