Need some help...
Hi, I need to know where to find Free software that will let me use all the textures and visuals such as This!
Note: I don't want a program that will mess up my system either ;)
Well first you need to patch uxtheme.dll. Its fairly simple and you can find good instruction here:
http://www.neowin.net/forum/index.php?showtopic=140707
Then download the file and unzip it. Put the msstyle file in C:/Windows/Resources/Themes.
The other contents of the zip file is the background(.jpg) and then the program that will turn your taskbar transparent. That one I have never tried.
Hope that helped.
