need help
in the tools section of the cleaner there is a system restore section, when selected it lists different restore point dates and times. how do i use one of those dates to restore to that point and can i do it with this software.. thank you for any and all help
No, you will have to use Windows System Restore process, which is designed for the job. I don't think that kicking off a system restore from an application is a good idea.
It's only used to delete the restore entrys. You will have to go start - all programs - accesseries - system tools - system restore
edit - beat me to it
