need help !
Hi. I tried to install the latest version Super V.2009 but Avira detects some file (ff2ogg.tmp & Mowavin.smk.tmp) as a trojan and heur. I downloaded the installer from author (erightsoft.com)
is it false ? or damaged setup file ? do you have same problem ?
Help, please !
Regards,
Try here and Avira will advise.
http://analysis.avira.com/samples/index.php
The file is too large to scan on any of the free malware scanning sites, however Firefox's Dr.Web Anti-Virus Link Checker didn't find anything, and neither did Avast Antivirus Home Edition. I'd hold off on installing it to wait for the next AntiVir daily update to see if it was a false positive.
:):):) Thank Hazel .As Andavari said, I'll be waiting for the result from Avira.
Regards
