Need help with Zone Alarm
No, you dont use regedit you use hijack this. select what Tarun said in hijack this (check box beside it) then click fix checked. Boot to safe mode first though.
Ok! :) I cleared all the problems with hijack this!Spybot find a few problems! :angry:
I will see if is working now!
Thanks to all ,for the help!
Tell us if it works. If not we will see what else we can do.
Make sure you allow the services to access the net.
Tarun,there is a program that is telling you what is wrong with registry?
I am just curious how it works!
Thx!
He wrote that program himself. It still impresses the hell out of me too.
Look here for more info:
http://forum.CCleaner.com/index.php?showtopic=1087&hl=
Did we fix your problem?
For the moment ,i need the internet, so i didnt disconnect! :) If is not working ,i will ask again for help! :)
Tarun, thx again for help!
Can you tell me how it works, hijack this?Just basics!I am not good with computers,but i want to learn! :)
I installed again ZA.Same problem :(
If i shutdown ZA, still not working.I uninstalled ZA,restart the computer,internet ok,disconnected for 10 min,connect back on internet ok. :unsure:
What could be the reason, that the internet connection is ok ,but cannot open any page on internet?
Any ideas, how can i fix the problem?
Thx!
When you installed zone alarm did you make sure you configured it for dial up?
I am not sure!I have to check!
Thx!
ZoneAlarm Pro any version has always killed my dial-up connection with my current ISP, I don't know if it's an advanced Pro only feature that does it. The free version has never caused connection problems.
When I had connection problems a few years ago and called my ISP one of the first things they asked was "Are you using ZoneAlarm Pro."
What version are you trying to use at the moment, free or pro?
Could you open up zonealarm, then click program control on the left hand side, click the programs tab top right, you will now see what is being allowed or disallowed to the internet.
Could you print screen this and post it in here, so we can see it? Or just tell us if that is easier.
ZoneAlarm (Free and Pro) both make pages take forever to load on dialup. Outpost Pro doesn't do that. ;) Perhaps the ISP times out because of that.
Tarun how good is the free version of outpost?
They quit updating it last I heard. Unsure though. Honestly I never used it.
Free version.I
All the programs are on green.I did this just to check.Not working.
What do you mean all programs are on green bavaria? they should have a tick or a cross or a question mark next to them in the access column.
Check the picture pls!
Sorry, was that pic there before?
It is not program access that is a problem then. You are actually allowing to much access.
Change all the ticks to crosses under the server column, it wont help the problem but needs to be done.
No, i just edit the post! :)
I know ,i changed all ,just to see if is working.But is not! :(
What browser are you using?
Is it internet explorer? If it is, have you kept your computer up to date using windows update?
I am just thinking it could be a conflict between zonealarm and an outdated version of IE.
Have you tried using a different browser such as Firefox?
