Need help with Zone Alarm
I have a problem since i installed Zone Alarm.Is working fine, but if i disconnect the internet, for a few minutes, it will not connect back.The connection to internet shows ok ,but no site is loaded.
When i restart the computer is ok ,so i asume is a problem with ZA.
Thank you!
What version of zonealarm are you using?
Is it the latest one?
Are you using default settings or have you changed anything?
This was a common problem a few versions ago, i myself suffered it, and had to uninstall, then reinstall an older version until they fixed the problem.
When you say the site dont load, what happens? do you get a 404 error?
Repost with more info, and i'm sure we will get it sorted.
I just downloaded yesterday,is the ZA Pro Version (free 15 days :) ) 5.5.094.000
I believe is the last one.Yes,default settings!
The internet connection is ok.I mean is making the connection but when i try to open a site i get that error 404,yes!
Was your computer clean of malware when you installed zonealarm?
This is really important because, if not you could have a missing root certificate which is normally the handywork of malware. This would bring up the 404 error amongst other things. Root certificates are normally only checked during installation of a program whereas zonealarm checks them all the time during normal use.
What security programs do you have and use?
I have Trend Micro Pcillin antivirus.I check my computer with BitDefender,PandaAntivirus.
AdAware,Microsoft Antispyware,CWShredder.I believe i have no virus or malware.
When i connect first time is ok.But if i disconnect the computer from internet that is!It will not connect again until i restart the computer.Maybe i should install only the free version not the pro?
I use the free version myself, I dont pay for software if I dont have to.
Give that a try then, uninstall zonealarm pro, run CCleaner, install zonealarm free version.
We will start again from there.
If that is successful, please post so that I know.
Ok!Thank you for your help!
Disable zone alram and connect to the internet. Then disconnect and then reconnect. If it works than its zone alarms fault and we can go from their if not than somethings wrong with your pc. Also try to scan with spybot search and destroy and post a Hijack this log.
I should have suggested that, rather than assuming it was zonealarms fault.
If i disconnect the ZA still not work!But if i start again the computer is ok.This problem is happened only after i installed ZA!
Just do what rridgely suggested first.
Right click the ZoneAlarm icon in the notification area (down by the clock).
Try the internet again. But not for too long.
I did this already!Still not work.I know is suposed to work(theoretically) but is not working.I disabled the ZA from start up.Still not working if i disconnect the internet connection.I am sure is a ZA problem because i have 0 problem until i installed this program.I am installing now, ZA free version :)
I will leave you to it for now, it is 2am and I need sleep, if it is not sorted next time I check I will try to help you more. Good Luck.
Thx!
Download This program and update it then scan and remove whatever it finds.
http://www.download.com/Spybot-Search-Dest...tml?tag=lst-0-1
Then get this program and when you open it choose scan and save log file. then cut and paste the log here so we can look at it.
http://www.download.com/HijackThis/3000-80...tml?tag=lst-0-1
Logfile of HijackThis v1.99.1
Scan saved at 9:22:13 PM, on 6/10/2005
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Softex\OmniPass\Omniserv.exe
C:\PROGRA~1\TRENDM~1\INTERN~1\PcCtlCom.exe
C:\PROGRA~1\TRENDM~1\INTERN~1\Tmntsrv.exe
C:\PROGRA~1\TRENDM~1\INTERN~1\tmproxy.exe
C:\WINDOWS\system32\ZoneLabs\vsmon.exe
C:\PROGRA~1\TRENDM~1\INTERN~1\TmPfw.exe
C:\Program Files\Softex\OmniPass\OPXPApp.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Softex\OmniPass\scureapp.exe
C:\Program Files\dvd43\dvd43_tray.exe
C:\Program Files\Trend Micro\Internet Security 2005\pccguide.exe
C:\Program Files\Softex\Weblink\WebLink.exe
C:\windows\system\hpsysdrv.exe
C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
C:\Program Files\Softex\OmniPass\Help.exe
C:\Program Files\Logitech\MouseWare\system\em_exec.exe
C:\Program Files\CCleaner\CCleaner.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\DOCUME~1\Owner\LOCALS~1\Temp\Temporary Directory 1 for hijackthis[1].zip\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://qca9.hpwis.com/
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://srch-qca9.hpwis.com/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.usconsulatetoronto.ca/content/c...ument=visa_wait
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://qca9.hpwis.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://srch-qca9.hpwis.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://srch-qca9.hpwis.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://srch-qca9.hpwis.com/
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://qca9.hpwis.com/
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://qca9.hpwis.com/
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O4 - HKLM\..\Run: [OmniPass] C:\Program Files\Softex\OmniPass\scureapp.exe
O4 - HKLM\..\Run: [dvd43] C:\Program Files\dvd43\dvd43_tray.exe
O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
O4 - HKLM\..\Run: [pccguide.exe] "C:\Program Files\Trend Micro\Internet Security 2005\pccguide.exe"
O4 - HKLM\..\Run: [WebLink] C:\Program Files\Softex\Weblink\WebLink.exe /boot
O4 - HKLM\..\Run: [Logitech Utility] Logi_MwX.Exe
O4 - HKLM\..\Run: [hpsysdrv] c:\windows\system\hpsysdrv.exe
O4 - HKLM\..\Run: [Zone Labs Client] C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\system32\msjava.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\system32\msjava.dll
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=36467&clcid=0x409
O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/SharedC...bin/AvSniff.cab
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.microsoft.com/v5co...b?1114270860733
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedC...n/bin/cabsa.cab
O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - http://a840.g.akamai.net/7/840/537/2004061...all/xscan53.cab
O16 - DPF: {80DD2229-B8E4-4C77-B72F-F22972D723EA} (AvxScanOnline Control) - http://www.bitdefender.com/scan/Msie/bitdefender.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{3BA7C1D9-A368-457A-9184-89060940ECFB}: NameServer = 206.47.244.53 206.47.244.109
O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxsrvc.dll
O20 - Winlogon Notify: OPXPGina - C:\Program Files\Softex\OmniPass\opxpgina.dll
O23 - Service: NVIDIA Driver Helper Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
O23 - Service: Softex OmniPass Service (omniserv) - Unknown owner - C:\Program Files\Softex\OmniPass\Omniserv.exe
O23 - Service: Trend Micro Central Control Component (PcCtlCom) - Trend Micro Incorporated. - C:\PROGRA~1\TRENDM~1\INTERN~1\PcCtlCom.exe
O23 - Service: SymWMI Service (SymWSC) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
O23 - Service: Trend Micro Real-time Service (Tmntsrv) - Trend Micro Incorporated. - C:\PROGRA~1\TRENDM~1\INTERN~1\Tmntsrv.exe
O23 - Service: Trend Micro Personal Firewall (TmPfw) - Trend Micro Inc. - C:\PROGRA~1\TRENDM~1\INTERN~1\TmPfw.exe
O23 - Service: Trend Micro Proxy Service (tmproxy) - Trend Micro Inc. - C:\PROGRA~1\TRENDM~1\INTERN~1\tmproxy.exe
O23 - Service: TrueVector Internet Monitor (vsmon) - Zone Labs, LLC - C:\WINDOWS\system32\ZoneLabs\vsmon.exe
Generated by Tarun's HijackThis Converter.
Created registry value. Safe to remove:
Changed registry value. Safe to remove:
Enumeration of existing IE's BHO's. Safe to remove:
Extra "Tools" menu items and buttons. Safe to remove:
IE plugins for file extensions or MIME types. Safe to remove:
Downloaded Program Files item. Safe to remove:
Thank you!Can you give me a little help? :) I am going to regedit and?
Tarun what do you think the problem could be then? He dosent have malware and his pc is up to date?
No, you dont use regedit you use hijack this. select what Tarun said in hijack this (check box beside it) then click fix checked. Boot to safe mode first though.
